交大建築所學士後建築組一年級期中評圖2010/5/6
文章 » 2010 5月 07 (週五) 8:28 am
老師:曾瑋、葉朝憲、洪大偉、張基義
學生:謝高漢、林雨玄、陳思因﹑陳又瑜、張益銓
張基義Chi-Yi Chang
chiyi@ms1.hinet.net
http://www.arch.nctu.edu.tw/
讓我們大家一起來推動台灣的全民生活美學教育。
張基義老師所拍攝貼圖於各網站之當代建築影像。
無償開放使用於非營利之教育推廣但須註明來源。
各雜誌、出版或有營利之用途使用,請來信另洽。
學校老師、同學自由引用分享,請載明作者即可。
文章: 691
文章hsinway » 2010 5月 07 (週五) 11:10 pm
能請問設計的題目嗎?謝謝
hsinway
文章: 33
註冊時間: 2007 12月 02 (週日) 11:20 am
文章 » 2010 5月 09 (週日) 12:50 am
謝高漢
林雨玄
陳思因
陳又瑜
張益銓
張基義Chi-Yi Chang
chiyi@ms1.hinet.net
文章: 691
設計題目
文章 » 2010 5月 10 (週一) 12:45 am
交通大學建築研究所2010春__Marc1
MISSION IMPOSSIBLE
Balancing
The bridge
Materials(材料):
Plywood(夾板)50cm*30cm*2cm X 2片X(2sets),
Wood & metal joints(自訂)
Architecture space and its construction are rooted in its tectonics formulation. Intertwined with the forces of labor and economy, joints are crafted / designed to link elements of planes and lines in space. You will be given three weeks to complete a series of tasks in order to train your brains to think abstractly with seemingly boring physical constrains.
Gravity: you are asked to understand “what is a cantilever beam?” — must have calculations and supporting diagrams.
Site & Concepts: concept formulation in relationship to the edge of the table.
Wood & metal joints: analysis of a particular kind of complex joints that you are interested.
Full scale model complete: no glues / no non-stiff materials / no angles other than 30, 45, 60 degree
The first set of model will be require an acute angle / no angles other than 30, 45, 60
The second set of model will be require the reverse shape of the first set and the angle 2 will be the angle1 +90°
The minimum contact area is required.
∮3>∮4 more than 10°
Duration:
03/04, 03/08, 03/11, 03/15,03/18 (評圖)
Requirements:
2 study models of joints chosen
2 Full scale model
Joint axonometric exploded — requires annotations
張基義Chi-Yi Chang
chiyi@ms1.hinet.net
文章: 691
